3-Point Hitch 3 point hitch jumping
   / 3 point hitch jumping #1
charlton289
Hurt Va.
2016 massey ferguson GC 1705
I have a 55 ferguson to 35 and just rebuilt engine. Tractor sat for about 2 years but the 3 point lift keeps jumping when under low lift pressure. Like bush hogging and grader blade. Is there anything I can do to keep it from jumping it is full of fluid. I was thinking it would quit after it ran for awhile but its still doing it. Any ideas would be a great help thanks.
   / 3 point hitch jumping #2
Check the hyd fluid filter. Any evidence of water in your fluid?
ok thanks I'll check it thanks.
   / 3 point hitch jumping #4
If you raise an implement like a bush hog, then turn off the tractor, does it immediately fall to the ground? If so, it is probably the seal on the 3 point lift bypassing and the position control keeps compensating for the drop. I'm not sure that tractor has position control, but the symptoms sure sound like it.
Yes it drops and drops when I push in clutch it has draft control. When I move draft control it don't do it as bad. Thanks
   / 3 point hitch jumping #6
Draft control can also do this, depending upon the circumstances.
OK I,m checking my manual from I&T shop manuals it don,t say much about what it could be just that it could be gummed up or have trash in it. I guess I,ll pull the cover of and check it out thanks for your input I,ll let you know what I find thanks.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
MASSAGE CHAIR (A58214)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
