3-POINT HITCH ON BOBCAT
   / 3-POINT HITCH ON BOBCAT #1
WINSTONSM
Tennessee
Looking
Has anyone used a 3-point hitch attachment on a bobcat with a blade or yard box? How well does the 3-point work? Thanks! /forums/images/graemlins/cool.gif
   / 3-POINT HITCH ON BOBCAT #2
I had one on a Case 1845c, Worked OK, but always working in reverse was a pain in the neck, pun intended
Did you have to use the blade in reverse as well? /forums/images/graemlins/tongue.gif
I ment to add, If you have a blade that will turn all the way around? /forums/images/graemlins/blush.gif
   / 3-POINT HITCH ON BOBCAT #5
Don't believe there is yet a blade than can turn 360 degrees.
My father-in-law uses one on his ford tractor for grading his driveway. He said I could use it but I only have a 773 Bobcat no tractor. So I wanted to try the 3-point attachment on it but I was wanting some input on it before I decide to buy one.
   / 3-POINT HITCH ON BOBCAT #7
Sorry for the delay, yes you can turn the blade 360 degrees and work forward, but difficult to mantain a grade and 773 will tear up a real good blade in a heartbeat. I only used it a couple time and ir t worked good, but not as good as a tractor
Thanks for the reply! I was wandering if the bobcat would mess it up. Some things are better left on a tractor. I guess I get to tell my wife I have to get a tractor now!!! /forums/images/graemlins/grin.gif I would really like to get a 6-way blade for the bobcat but for the amount I would use it and the cost of it, Well it just wouln't be worth it. /forums/images/graemlins/tongue.gif. There used to be a cheaper version of a grader blade for the bobcat several years ago, but I can't seem to find one anymore. Any help?
   / 3-POINT HITCH ON BOBCAT #9
You might be able to find one used, but it doesn't appear that Bobcat manufactures it right now. /forums/images/graemlins/frown.gif
   / 3-POINT HITCH ON BOBCAT #10
Give Kwik-Way a look, they do tend to be a bit pricey but maybe their skid steer attachments are more reasonable.
Kwik-Way
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
