3 point hitch roller?
   / 3 point hitch roller? #11
Rolling it won't stop erosion. As Mark suggested crusher run may be the ticket or fill the rut with 3/4 crushed stone. No fines or sand in it to wash out.
   / 3 point hitch roller? #12
Or maybe the best solution is adding some drainage ditchs on the sides, and water bars across the driveway (or a nice crown on the drive) for proper drainage. If the OP is letting the water run straight down the road, even with crush run on top, it will likely wash out the loose soil underneath it in places over time.
   / 3 point hitch roller? #13
Here is a photo of our entrance road after 18 tons of crusher run dumped and graded with a JD 3032e and then 6 tons of gravel after 5 straight days of heavy rain.
Any other year, there would have been huge ruts at the bottom of both grades.
   / 3 point hitch roller? #14
Von, I have a water tank, angle iron, and welder. Where did you get, and how did you mount the bearings for the axel to turn in?? Colud you take some pics of that part of your roller and post for reference please. been wanting to do this for a couple of years.
Thanx, Bert
Just so ya know, you're replying to an almost 12 year old thread... May not get the response you're looking for.
   / 3 point hitch roller? #15
That's ok. At my age I'm just catching up with real time news. What was I doing now?
CAST IRON POTS & KETTLES (A58374)
CAST IRON POTS &...
2015 FREIGHTLINER M2 26FT BOX TRUCK (A58017)
2015 FREIGHTLINER...
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
2015 Ford Focus (A56859)
2015 Ford Focus...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
Auger Drill Bit (A56857)
Auger Drill Bit...
