3 point is leaking down
   / 3 point is leaking down #1
Knifer
Bronze Member
Winter Haven
Massey,JD 2010, International W6. '42 case
The hydraulics lleak down when you turn it off or fully depress tgr clutch is my cylinder bad and is it hard to get too to fix!
   / 3 point is leaking down #2
Most all 3pt systems leak down, Some faster than others.
If you want to know if the 3pt cyl seals are worn, screw in the descent or lock valve with a load on the 3pt.
A new tractor 3pt may stay up for days or weeks, and others , you can watch them drop.
If you can't lock it in the up position for transport, you probably needs seals.
We took it apart today found one oring bad and the piston rings were leaking. Got new ones coming.
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
