3-point lift troubleshooting
   / 3-point lift troubleshooting #11
for sure not familiar with that setup.
can you describe how it is plumbed, and how you know you are getting oil from the pump.
after the pump where does it go.. a relief valve and spool valve of some sort then to the lift cyl?
does the machine have remotes running off the same pump? do they work?
any sort of aux control valve or diverter that may be sending flow elsewhere and locking out 3pt?
post back.
soundguy
   / 3-point lift troubleshooting #12
I used to own a Case 1410, I'm not sure if it is the same but if it is, there is a valve down near the floor on the right side of the seat that controls the flow of hyd fluid to the 3ph. The knob of the valve moved in and out toward the right tire. If I remember correctly push the knob in and the 3ph was turn off and the loader moved faster, with it out the 3ph worked but my loader moved very slow. Hope this helps...
DanK
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
Ford 8510 (A53317)
Ford 8510 (A53317)
2017 Takeuchi TL12R2 Skid Steer, S/N 412100259, Kubota Diesel Engine, Joy Stick Operating Controls, (A59076)
2017 Takeuchi...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
