Dec 27, 2023 / 3 point lift #1 Joeshelton New member Joined Dec 27, 2023 Messages 2 Tractor Yanmar1702 Have a yanmar 1702. Three point lift will not lift at all. No noise. The pump is pumping to the cylinder but will not lift.
Dec 27, 2023 / 3 point lift #2 JCoastie Platinum Member Joined Aug 29, 2020 Messages 846 Location Coastal AL Tractor LS MT240HE happened to me, did you check the knob under the seat? Mine moved itself one time and the 3pt was locked up. Weirdest thing! Last edited: Dec 27, 2023
Dec 28, 2023 / 3 point lift #3 C camshawn Gold Member Joined Oct 28, 2012 Messages 327 Location Langley BC Tractor Mihindra 3616 The knob is a flow control valve that determines the down speed of the 3point hitch. If your hitch won’t lift and your pump is pumping oil, the possibility that the o-ring on the cylinder has failed.
