bironacad
Platinum Member
Soon after you hit a bump with a heavy implement raised, and it falls to the ground, you will become painfully aware of the real issue.
larry
Beaudy! Speed bumps for Ottawa! What? just wanted to pitch in, lol.
larry
Ballasting wont keep from breaking the 3ph internals -- and would normally make it more likely because the tractor front would not lift to moderate the impulse.
larry
Back to the OP's question - when I was getting my tractor I was limited on the size of Rotary Cutter I could handle by the max front suitcase weight available. That was before I added the FEL. So then the suitcase weights got scrubbed and the "useable" weight capacity on the 3pt hitch went up a lot with the FEL - which may also explain some of the difference. The weight they tell you is allowable doesn't assume you have a FEL mounted.
