3-Point Pallet Mover
   / 3-Point Pallet Mover #11
Markct: I believe what you have is what I'm looking for. I will start looking in the junk yard for a set of forks. Thanks for the help.
By the way, how do you include a picture in your response?
   / 3-Point Pallet Mover #13
i bought a set of forks from a forklift repair/sales shop. they had 30 or so sets for me to choose from.
   / 3-Point Pallet Mover #14
wvbartman, where ya from, it doesnt say on your profile, if your nearby i may be able to build a simular set, altho there realy not that hard to make if you have a large drill press or milling machine and a welder, i actualy bored the holes on our horizontal milling machine since our drill press is a bit light for heavy drilling. the forks have held up great tho to all the abuse my tractor could dish out, i often use fork extensions made from 8 inch channel that are around 8ft long to move larger stuff like sheds, and last weekend i used them to move a slide in truck camper, that realy made the front end light but the forks held up fine, i use them with my homemade hyd toplink usualy which is a huge help, makes it easier to get under stuff and to dump stuff off the forks
Pekabu: How much did they charge you for a set of forks?
   / 3-Point Pallet Mover #16
WVBartman -
Here's a nice site (seeing as you have a *nicely sized* tractor):
Attachments International
Maybe also:
Carver Equipment
Last - but certainly not least - try:
Markham Welding
Lots of folks here rave about Markhams' toothbars - I'm inclined to getting one from them too - if I don't build one myself.
I also picked up some used forks and welded up a 3PH frame:
Bigger Pic
I'm no expert welder - but my 3PH can only lift @ 1000 lbs - so I'm very confident about its strength up to that range. I'd have to be a bit more practiced until I felt comfortable with one for a 2000 lb capacity.
Hope one of those links helps,
Dan
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2012 INTERNATIONAL WORKSTAR 7500 HYDROVAC GUZZLER TRK (A53843)
2012 INTERNATIONAL...
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
