ffclassic
I have the same tractor and WR Long valve. The power beyond port from the loader valve feeds the WR valve and then the return port from the WR goes back to the rear. There are 2 metal pipes under the tractor that are the supply and return for the hydraulics.If the tractor did not have a loader the factory puts in a "U" pipe to return the fluid. The valves must be in series ie-- from pump to loader valve> loader valve to WR Long valve> WR back to tractor return line. Make sure that the return port of the WR connects to the metal line that goes to the rear. It connects close to the rear remote valve. Also check the fluid level, the extra hoses may have dropped the fluid level. Kubota had to add some fluid to mine. Also you can always contact Nelson @ WR Long. You can find his contact info on his website. Hope this helps, Matt.
