3 Point Woods Dual Forklift
   / 3 Point Woods Dual Forklift #11
I can see some good uses for the three point lifts over the loader forks - mostly for heavy loads and/or over rough ground. They may work pretty good for unloading off the side or back of a semi-trailer or for feed, seed, sod and such....or if your loader don't have the grunt to get it done.
If I needed em....I could see paying up to $1000 for a good used set up. If they got too cheap....someone is going to use that cylinder and frame for a log-splitter.
Well ended up buying this forklift. Had to pay close to the upper end of what I wanted but it is in great shape and about 1/3 the cost of a new one. I should get it off the truck later today, thankfully I have a loader and a chain!
Pics as everyone likes:
   / 3 Point Woods Dual Forklift #14
That's a really nice looking set-up. Just be real careful with any heavy loads up high. I think I'd limit myself to paved surfaces for that sort of work.
-Jim
Thanks for the thoughts! I never carry heavy loads up high, always as low as possible.
   / 3 Point Woods Dual Forklift #16
Or you can make your own from a scrap mast as i did.
rated for
1100 pounds at 9ft lift
or
3300 pounds at max 3ft lift
Works a charm. You'll need a valve for a single action piston.
The height is not a problem if you make the base of the mast frame wide enough and NEVER lift anything high with the mast lifted of ground by the 3pt.
Driving with a pallet 1ft in the air is stable on paved roads.
I marked my barn floor so i know where to lower the mast and then lift the pallet all the way up with the mast and FEL bucket on the ground.
As an extra I re-made my 3pt hitch so it accepts the forks for quick ground level moving of pallets and pallet boxes with firewood.
That is quite the deal! I did not need anything quite that big! Great job!
   / 3 Point Woods Dual Forklift #18
I just bought a woods lift from the city of Tallahassee fl. after seeing the picture installed i cant wait to pick it up:thumbsup:
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2011 26PS PROWLER 5TH WHEEL RV (A55745)
2011 26PS PROWLER...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
New/Unused CFG Industrial MX15RX Mini Excavator (A54865)
New/Unused CFG...
