3 PT stump grinder
   / 3 PT stump grinder #1
n92687
N. Fla
Massey 1533
What is the latest on this attachment? Anyone offer a good one at a reasonable price that I can use on my compact tractor 33HP Massey?
John
   / 3 PT stump grinder #2
$4 to $5 thousand if you call that reasonable. and up and up. Not too practical unless you are going into a sideline business. I rented a Vermeer 252 not long ago and got about 20 done in a day for $150. I have a fellow coming over in a couple of days with a big Vermeer on tracks with a 60 HP Cat engine and he is going to do 20 more big ones for $300.
As long as I can rent or get it done for this price I don't believe I will be sinking $5K into one. Give a little more detail of what you are doing and what you plan do do with it after you grind everything in your place.
I actually had pines cut on 3 acres, but now I am just trying to clear 1 acre and prep it for planting. Trees were 8-10 in diameter. It is a mess, but I figure if I can clear the acre of stumps and let mother nature take care of the other stumps on the other 2. I can use the other 2 acres later.
I recieved a quote of $150 per day for a rental. That it probably the way to go. $5000 is far too much. I thought they might be about $1500. Then it would be well worth the investment to have it sit around after I am done.
JOhn
   / 3 PT stump grinder #4
If you have some time to wait before you remove the stumps use some 28% nitrogen. I've done it by taking a cordless drill and popping some hole in the top of the stump. Fill the holes with 28% and once in a while go back and top the holes up. By the next year the stumps will be rotten enough to chip up with a shovel.
   / 3 PT stump grinder #5
Why grind stumps when this stuff works pretty quick.. Might irritate the neighbors though.
Ethylene glycol dinitrate, 70% and Nitroglycerine, 30%:eek:
1 or 2 sticks under a stump light the fuse and run like crazy
   / 3 PT stump grinder #7
Grampa taught me that trick too but he used a dash of diesel fuel and urea as well. That'll make a stump jump real high. :)
As for where to find 28%, around here we get it from our local ag-fertilizer dealer. What do local farmers around Martha's Vineyard, Mass. use on their corn? 28% or straight anhydrous?
   / 3 PT stump grinder #8
Homeland Security will be visiting you real soon now...:rolleyes:
   / 3 PT stump grinder #9
we aren't oversupplied with corn farmers, but I'll drift by and ask. Most stuff is bought off island in any case. And most farming is organic - don't know if that makes a difference.
   / 3 PT stump grinder #10
I've been off of the farm now for quite a few years so I'm not sure what the organic guys use to get the nitrogen content up in their soils. You could always try a place that sells yard fertilizers. On the bags of fertilizer there is usually a 3 digit code X-X-X. The first number is the nitrogen percentage, the second is the phosphorous and the last is the potassium. Just look for one that has a really high value for the first number and really low for the last two.
Try mixing the fertilizer up with some water and pour the paste in the stump holes. Might be a quick solution instead of hunting down some 28%.
Two Post Car Lift (A50120)
Two Post Car Lift...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
John Deere 5100M (A50123)
John Deere 5100M...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
2004 Ford F-550 4x4 Auto Crane 4004EH Crane Service Truck (A51692)
2004 Ford F-550...
