3 PT stump grinder
   / 3 PT stump grinder #11
I also looked into the stump grinders. Woods has 2 models, one for larger tractors, the other for smaller ones. This is the smaller one:
Woods Equipment Company - 15-50 PTO HP Stump Grinder - Model TSG50
A bit cheaper than the other brands.
I was quoted in the range of $3600. That included the hyd fittings to go on my 2 rear remotes. One remote works the horiz cyninder, the other works the vert cylinder.
After thinking about it some more, I decided to hold off and not get one. I figured for another 3 or 4 thousand I should just get a backhoe and be done with it. More money, but better spent?
   / 3 PT stump grinder #12
n92687 said:
I actually had pines cut on 3 acres, but now I am just trying to clear 1 acre and prep it for planting. Trees were 8-10 in diameter. It is a mess, but I figure if I can clear the acre of stumps and let mother nature take care of the other stumps on the other 2. I can use the other 2 acres later.
I received a quote of $150 per day for a rental. That it probably the way to go. $5000 is far too much. I thought they might be about $1500. Then it would be well worth the investment to have it sit around after I am done.
JOhn
Nope, $1,500 will not get you into the ballpark and the $4 to $5K grinders are probably not suitable for going into business. The man showed up yesterday afternoon with a $50K Vermeer on rubber tracks and made quick work of over 20 NICE SIZE stumps in less than an hour. If I had rented one it would have taken me the full day to do what he did. He pocketed $300 and was off to another job at 5:00 PM. Well worth the money I paid him.
To the other post about using 28% nitrogen - why not just use pure amonimum nitrate? Isn't that 100% nitrogen???
   / 3 PT stump grinder #13
Dave,i'd agree that a hoe is money better spent than on a stump grinder.
That being said..... a PTO stump grinder is high on my list of tractor wants. I kick myself in the rear for not buying the ONE pto grinder i've ever come across used, that was actually within a reasonable driving distance. Seller was asking $2 grand..... i won't make that mistake again!:mad:
   / 3 PT stump grinder #14
mreeb - thanks, great suggestion, seems obvious now that you mention it, I could kick myself.
Ductape - if there is a used pto stump grinder in the area at that price, we'll be racing each other for it :D
That said, I don't think they make any sense to own unless you can find a used one cheap. For that money cheaper and easier to get them done by a proper professional machine.
   / 3 PT stump grinder #15
John, What are you going to plant where the pines were? If you don't get the stumps out they will eventually rot down and you'll have a depression everywhere there was a stump.
   / 3 PT stump grinder #16
It is close to 95% to 99.9% nitrogen depending on moisture content. If you could find a supplier for it that would be even better.
   / 3 PT stump grinder #17
Charlesaf3 said:
we aren't oversupplied with corn farmers, but I'll drift by and ask. Most stuff is bought off island in any case. And most farming is organic - don't know if that makes a difference.
That post hole digger on your avatar...
Just wondering if there are wood boring bits (augers) available for that kool tool.
It seems a few cuts of 6 or 9 inch diameter holes through a stump would make it much easier to destroy with say a bucket edge or box blade ?
Might be able to just reduce the whole thing to holes ?
   / 3 PT stump grinder #18
I'm pretty sure Home Land Security watches this stuff real close also.
I've always wondered about that also. Take a PHD and just put holes a few feet from the stump to rip through the roots, then pop the stump out.
Wedge
   / 3 PT stump grinder #19
I recieved a quote of $150 per day for a rental. That it probably the way to go. $5000 is far too much. I thought they might be about $1500. Then it would be well worth the investment to have it sit around after I am done.
JOhn
My brother had some stumps to get rid of. He bored into them with a long drill bit. He would go out a few time a week and fill the holes with diesel. After about a month he lit the stumps. They burned for close to a week but burned the stumps and roots down to about 4 feet. He back filled with dirt and was done.
   / 3 PT stump grinder #20
Wedge
I tried this, but it didn't help with the roots. the auger bit either stops on top of the root, or it corkscrews down alongside it and you need to unscrew the auger by hand. For removal, the backhoe is the tool of choice. I too was wondering what the OP intends to plant. Any kind of tilling will most likely still encounter the ground stump heads...
Now the center bore idea using a PHD sounds interesting... But any way you look at it, stump removal is a lot of work, at least with the backhoe, the heavy work is done by the machine.
Gotta go and dig out another stump now, Good Luck with your field.
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
Trsmima Retractable Fall Arrester (A57454)
Trsmima...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
Ryobi Drill (A57454)
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
