3 pt. Won't Lift Heavy Loads (Anymore)
   / 3 pt. Won't Lift Heavy Loads (Anymore) #11
Hi J_J sir,
I am building one log splitter of 20 ton capacity.
I am selecting components needed for that.
please guide me.I am new to hydraulics.i am going through formulas in surplus center.
How much HP engine is needed,what dia. of cylinder is needed.Pump sizing.
Please tell about,how to build a hydraulic system for log splitter of capacity 20 tons.
Thanks in advance.
chandra
   / 3 pt. Won't Lift Heavy Loads (Anymore) #12
   / 3 pt. Won't Lift Heavy Loads (Anymore) #13
Thank you sir,
The 4 inch. cylinder have area of 3.14*4*4/4 gives 12.56 square inch.
The required force is 20tons gives 44000 lbs of force.
so the pressure setting is 3503.15 pounds per square inch.(am i correct sir?)
16 gpm flow is required by the pump.is it over all flow of the circuit?
gpm*psi/1714 gives the required horse power to drive the pump.
(16*3503)/1714 gives 32.17 hp?? (please correct me here)
How to decide the flow .i.e. total flow required by the system?
i am calculating total volume of fluid in each part of circuit or how to calculate GPM of pump.
i am confusing ,please guide.
chandra
   / 3 pt. Won't Lift Heavy Loads (Anymore) #14
GPM's determine the speed of operation, and pressure determines the torque.
If you have a 10 GPM pump the pump will try and pump 10 GPM. Your valve will determine the amount of fluid you send to the cyl .
Most hyd pump are rated to about 3000, and a few hyd pump will go to 3500 psi or greater.
Log splitter pressure usually are in the range of 2500 to 3000 psi.
You will only have pressure when there is resistance to the force of the pump flow.
Most hyd systems will have a relief pressure that will protect the pump, and should the pressure rise to the relief setting, the pressure will be relieved to tank.
To compute data for you hyd's, go to Surplus Center - Tech Help
Select tech help, select calculators, and fill in the blanks.
   / 3 pt. Won't Lift Heavy Loads (Anymore) #15
Thank you J_J sir for your input.
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
