3-way valve vs. 4-way valve
   / 3-way valve vs. 4-way valve #1
Skidmark25
North Shore, MA
B7610
Can anyone tell me the difference on my FEL valve between a 3-way valve and 4-way valve? B7610 LA352 FEL
Is there a simple way to identify the type I have?
I was told that I would need to have a 4-way valve to operate a front-mounted blower.
Thanks. . .Skid
   / 3-way valve vs. 4-way valve #2
If the part number of your valve is B2006 then you have the 3-way.
If the part number is B2007 then you have the 4-way.
There should be a tag on the valve with the part number and serial number. The same valves work for the LA272 and LA352.
   / 3-way valve vs. 4-way valve #3
An even simpler way, at least on my BX1500, the 3-way stays with the loader, the 4-way stays with the tractor.
Jim
   / 3-way valve vs. 4-way valve #4
</font><font color="blue" class="small">( An even simpler way, at least on my BX1500, the 3-way stays with the loader, the 4-way stays with the tractor.)</font>
That's because loader designs changed in mid-production for most of the BX series. The older design had the valve, regardless of flavor, staying with the loader when it was removed. The newer design removed that restriction.
Couldn't find the tag but pulled down the schematic from Tractor Smart and I have the 4-way. The LA352 owners manual recomends using the 4-way
UNUSED LANDHONOR SD-22-72W NO TILL SEED DRILL (A54757)
UNUSED LANDHONOR...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
