300cx loader dump cylinders leak down
   / 300cx loader dump cylinders leak down #1
BigMike50
Uranus
2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
brand New loader. Im aware that these units leak down a little, however, im unaware of the rate. I had about 400-500 pounds suspended in the air with chains on my bucket while doing some welding today . I had to go back to the machine and start it up every 5 minutes to recurl the bucket because it kept drifting. Not the lift arms, only the curl feature.
   / 300cx loader dump cylinders leak down #2
That may/may not be excessive. You can discuss your observations with the shop supervisor at your dealership. He's got a 300CX technical repair manual which includes a max/min leak down time for the curl and boom cylinders. He can provide that info to you and...
You can test the loader at home and record the time and rely that info to your dealer. Depending upon what you learn... they may elect to repair the cylinders.
AKfish
   / 300cx loader dump cylinders leak down #3
Have to correct the bucket curl every 5 minutes sounds excessive to me.
   / 300cx loader dump cylinders leak down #4
people have had this before
   / 300cx loader dump cylinders leak down #5
This is what Deere thinks to be acceptable
   / 300cx loader dump cylinders leak down #6
I had this same issue with the loader on my 2520 leaking down (main cylinders not bucket) and deere said it was within tolerances. Interesting to know that it varies by the tractor and not just the loader. Says to me that the leakage is occurring more in the tractor valve than the cylinders.
Surprises me that a 45 loader on our old 630 two cylinder, will stay up for days with a load on it without leaking down. I'm sure those cylinders and the hydraulic valves have had 30 years of use without being rebuilt. Just designed for a different time.
   / 300cx loader dump cylinders leak down #9
Mike, You paid good money for that JD and this leak down is unacceptable. Get this fixed right.
   / 300cx loader dump cylinders leak down #10
Mike, have you checked all the hose connections on the loader...?.....My 200cx had a couple of lines that were leaking a little fluid and needed tightened when new .......just a thought.....
Yeah no leaks. Yeah I'm gonna time it tonight to be exact and send an email to service manager. I can seriously watch the bucket dump on its own
ok so heres the video for those that are curious. the video is sped up. It is dropping at 3 inches a minute. send email with video to the service manager.
   / 300cx loader dump cylinders leak down #13
:eek:....WOW.....thats definitely not right.......Hope the dealer gets it fixed for you....
yeah. ill let you know what the response is when I get it
   / 300cx loader dump cylinders leak down #15
Great video Mike!
Sorry you're having trouble, seems like it's always something :(
On a brighter note, thank god for warranties. My dealer has been to my house 4 times for 4 different fixes in 7 months!
They say if something goes wrong it's most likely to wrong in the first year. I hope that holds true because these implements only get 1 year (tractor 2 years).
Good luck with the fix!
Thanks! I swear I have the crappiest luck with everything new
got a call first thing this morning from the service manager because he got me email and video I sent last night. They are very sorry about the issue and are gonna pick up the machine and take care of it. Good service department that doesn't waste any time taking care of the customer. He said, yeah definitely something wrong there! I scheduled for next week so I can get a few things done this week.
   / 300cx loader dump cylinders leak down #18
good to hear....:thumbsup:....thank goodness for a good service department.....keep us posted on what they find....:)
I will for sure. next week sometime
   / 300cx loader dump cylinders leak down #20
Good news! Great idea on the video.. the proof is in the pudding! ;)
AKfish
iDrive TDS-2010H...
2018 JOHN DEERE 333G SKID STEER (A60429)
2018 JOHN DEERE...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
