301 won't stay running
   / 301 won't stay running #11
The last inj pump I've had rebuilt was done by Southwest Metro Fuel in Ft Worth.
Thanks for all the help, I replaced the check valve yesterday. I also pulled off the top of the injector pump and there was quite a bit of crud in there. I blew out all of the fuel and crud from the injector pump then fitted it up. Unfortunately when putting it back together I accidentally jammed the fuel shut off solenoid lever into the throttle mechanism so, when I started it it instantly went ungovernered full throttle. And because the lever was jammed, it wouldn't shut off when I turned off the key. I thought that it would blow for sure. Fortunately I was able to disconnect the fuel line at the injector pump in time. I then put it back together correctly and it hasn't had a problem since. I worked with the tractor for about 8 hours today and didn't have any problems, so I am hoping that the pump is ok.
   / 301 won't stay running #13
Eventually the inj pump will require a rebuild or at least the governor ring replaced. If engine ever start revving up on it's own then the inj needs attention immediately.
   / 301 won't stay running #14
Going through the same thing on my Deere 350C dozer...
It has always ran well... had an all weekend job planned stumping a Christmas Tree Farm and about an hour in it lost power and quit...
Turns out the check valve for the return was plugged... cleaned it and good to go for about 10 minutes... repeated a few times and each time found a brownish fiber and little rust particles...
Removed the Check Valve and it ran fine all day Sunday...
From what I read taking out the check is only a temporary fix...
I have no idea how long temporary is... hours, weeks, months or the downside of running without it.
2025 GPS Equipment Trailer (A56858)
2025 GPS Equipment...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
