3010 and 2000 lb skids
   / 3010 and 2000 lb skids #11
Thats the problem w/ Yukons he should have had a H2.
He could have gotten a heli-lift, or he wouldn't have been stuck anyway /forums/images/graemlins/grin.gif
My backhoe front or rear could pick up and shake my truck NO problem.
   / 3010 and 2000 lb skids #12
Daryl,
Turbo?
What engine and what turbo? It might be interesting to study this combination. I wonder if Kubota makes a stronger variation of one its motors for just that purpose???
   / 3010 and 2000 lb skids #13
I don't know. Usually a turbo charged engine will have a slightly reduced compression ratio for the engine to internally handle the added strain of turbo charging. The Kubota engine in our 770 Bobcat is a 4 cylinder Turbo charged Kubota diesel. I don't know if Kubota builds this engine differently than the tractor engines as I don't have a shop manual on it. Kubota builds engines for a lot of specialized equipment manufacturers, from generator manufacturers to Bobcat's. I was wondering what would happen if I fabbed an intake manifold and added a turbo to my 5030. I'm sure I'd have to at the very least, install a thicker head gasket or spacer plate to reduce the compression ratio. Beacuse the engine has overhead valves, I'd need longer push rods and a bunch of other parts so I probably would not do it. Besides, it's new and under warranty. Maybe in a few years, but by then I'll trade it for another one anyhow.
In a nutshell:
Most engine manufacturers don't redesign an engine for turbo charging, they just lower the compression ratio to a manageable level. If you turbo charged an engine without reducing the compression, the internal heat and stress from the added air charge would destroy it.
Daryl
Forage Services, L.P.
Ford E550 Bucket Truck (A53117)
Ford E550 Bucket...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
Link-Belt 75X3 (A50123)
Link-Belt 75X3...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
