3016hst Mahindra slow crank
   / 3016hst Mahindra slow crank #1
Beaujo
Mahindra 3016 hst
Have a 3016hst using it the other day getting garden ready was running fine went and put fuel in it and shut off, once done fueling went to start and acted like battery was dead, tested battery and it was on the weaker side so replaced with new, still the same thing maybe crank one or 2 revolutions then just stuck acting, took starter off and found it was on last leg as well, so bought a new starter tried to spin over once normal and then back to barely cranking at all install new cables as well. At a loss can a bad hydraulic pump be my issue acts like the starter is under a major load?
   / 3016hst Mahindra slow crank #2
I’d check battery cables/clamps. I had to replace the positive cable and clamp because of corrosion inside the cable on a similar machine. Also when the battery is out might want to disconnect the ground wire to battery tray/frame connection and clean it up with a wire brush or emery cloth,
   / 3016hst Mahindra slow crank #3
   / 3016hst Mahindra slow crank #4
doneill, he replaced the cables . . .
   / 3016hst Mahindra slow crank #5
Is the pto off
Is Transmission in neutral
Is the clutch pedal button solenoid out of adjustment ?
How about where the cable connects to the starter.
Did the starter come with a new solenoid??
How about an update?
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
