304J Hydraulic fittings leaking a tiny bit
   / 304J Hydraulic fittings leaking a tiny bit #1
ggreyjr
lexington,ma
John Deeer 304j
Is this normal for several of the fitting going to bucket to leak. Not much, but you can see it on the threads
   / 304J Hydraulic fittings leaking a tiny bit #2
No. Fluid is supposed to be INSIDE pipes and hoses, not outside. OTOH, all old tractors tend to seep a bit, but generally it's from areas that aren't easy or cheap to fix. For simple fittings, however, you should re-assemble them so that they don't leak.
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
Sawmill YC-26G W/ Gas Motor (A47477)
Sawmill YC-26G W/...
Galvanized steel fence (A53424)
Galvanized steel...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
