30hp CUT: New vs. Used ?
   / 30hp CUT: New vs. Used ? #11
It depends on how comfortable you are working on your tractor. As has been said, at 300 hours it should be good for quite a while. If you do all the work on it yourself that extra $6000 will go a long way towards any repair needed. I bought my '01 with about 350 hours, and mine sounds a bit more heavily used than the one you're talking about. Other than maintenance items, I've only had to spend about $25 to buy a battery box and some Ford blue paint to fix battery corrosion.
   / 30hp CUT: New vs. Used ? #12
That's a good point Michael. I feel the same about having a dealer service the tractor. If you have the ability, service it yourself. Then you'll know what you have rather than depending on a dealer to find everything he can wrong with it to run up the bill. I'd freak out to pay a dealer $500-$700 to change the fluids in my tractor.
   / 30hp CUT: New vs. Used ? #13
He's going to brush hog 10 acres once or twice a year and probably do 5 hours of snow management each winter. Not heavy use.
My 2 cents; used for sure. Wth the planned hours it will hold its value well if it's kept inside. You're talking about putting on less than 30 hours per year I'd say. The new one will be worth about the same as the used one 10 years from now IMHO.
2844 (A54757)
2844 (A54757)
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
UNUSED RAYTREE RMSC78 - 78" SOIL CONDITIONER (A54757)
UNUSED RAYTREE...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
7033 (A51691)
7033 (A51691)
