30X40X10 Pole Barn
   / 30X40X10 Pole Barn #11
Ditto on the higher walls. As a guy with doors too short for my newer tractor with canopy, I can't emphasize enough going higher. As a result I have to put the canopy on after removing the tractor from the garage. It may be that one day you will come a across a fabulous deal on a piece of equipment that won't get through smaller doors, or trade in your tractor. going higher costs more in the short term, but costs far less if your equipment needs change.
Other than that, you can get windows fairly cheaply if you look at the right places. I like windows for the light and the ventilation. Sometimes you just need a crack on either side, sometimes you will have every door and window open. You can always put film on the glass if your concerned about prying eyes. As far as security goes, if they want in they are going to get in so I wouldn't be concerned about windows. Opening the garage door isn't always the best option.
There are far too many concrete posts on this site for floors for me to offer anything meaningful.
One thing to consider before building is drainage. If you ever have water there, in or around the garage, consider a floor drain or several. I would also consider heat sources - future tense. You may eventually want to run a furnace or stove and it is always better if you plan for the possibility now. When they pour your slab, you may want them to stub through the floor for any other possible entry or exits for your garage. I had them stub in two corners for me, one I ran power through, and the other I have for water.
I have roll up doors, and came across a cheap but good door opener. Sure is nice in winter not to get off, go open, get back on, get in garage, get off and close the door. Course you guys don't really have winter there...but that is another thread.
Good luck.
   / 30X40X10 Pole Barn #12
12 to 14' high walls are better. Mine is 10'. Wish I had gotten 14' many times. A 10' wide door gets real small if trying to back a trailer or large implement into barn. My doors are on one end and side. Put the doors at least 4' off the walls. This give room to work or get around item put in barn through large door. A 30 to 40' wide barn does not allow a lot of room inside to maneuver tractor and attachments. Putting doors off center allows of more storage on one side.
   / 30X40X10 Pole Barn #13
Lots of things are 10' tall, When designing my 24x36' pole barn I wanted 11' rafter bottoms and I'm so happy today that I did! You will not regret higher ceelings.
2nd the thought of the 2' upper section (semi see through) filler for lighting! That's what I have and it's great!
Roll up door is nice for "Automation" as in remote opener, but for full use of the space a Lateral opening door on roller bearings (hanging) would be better access. It's all in how you want to enter it. You decide. A hanging or other type "Barn" doors will require some way of locking, where as the automatic door is somewhat locked when down by it's self. I use latches on the inside and a side (people) door with dead bolt for security.
If you are going 4" cement floors you may want good re-enforcement. 4" seems a little thin for dump truck and tactor. Put in 10 yrds pee gravel base then 6" WET cement over it so have 8-10 inch equivalent. nice and solid!
Cheers
The worst thing about 10 12 and 14 foot ceilings is they cost a lot more to heat and cool.
   / 30X40X10 Pole Barn #14
I recently had a 30x50x10 barn built. I was looking at roll up doors but I decided on a 20 ft split slider on the side and a 12ft split slider on the end. It was actually cheaper going with the 20 ft slider than 2-10ft roll up doors. I also had three sky lights installed. I liked the light that they provide. The 10 ft walls work for me but if you have large farm equipment or may in the future I would go higher with the walls. The 10 ft limits you for future uses....
   / 30X40X10 Pole Barn #15
We often think we will live forever at our current spot, however, with a view to future resale to the widest possible market, I'd suggest minimum 45' length - 50 would be better and minimum 16' ceilings with 14' doors - at least one 12' x 14' if not both.
Many Class C motor homes or 5th wheels will not fit a 10' door. Most Class A motor homes are at least 12' high if not higher and many are 40'+ with rear ladder & mirrors. Take a look at the clearance needed for OTR truck / Tractor with sleeper cab etc. Independent Truckers are always looking for a place where they can work on / store their truck / trailer. Many trailers are 53' to the nose so if you went 55' - 60' and ever wanted to sell - you'd have a wider potential market.
Even if you don't sell you'll never regret having the extra height. If you go 16' or greater ceiling you can have an area with 8' ceiling and storage / office / mezzanine above, still with approx 7' headroom.
   / 30X40X10 Pole Barn #16
While what you say makes sense (it did to me for the longest time) but this past spring we were talking to a family friend who is an appraiser by trade about building a garage/shop....what HE told us was that if you go TOO big you're pouring money down the drain because the amount of people willing to PAY for the super garage....so essentially its costing more to build on your end but you'll never get it back on the back end.
Bigger IS better, but too big is bad...If you go TOO big you could actually DECREASE the value of your home & property....
Rule of thumb from him was to build something similar as the properties in the area... If all your neighbors have 80'x160'x16' garages...that would probably be best for value...
   / 30X40X10 Pole Barn #17
The OP didn't actually give us much to go on regarding, size and location of his property, demographics of surrounding area or intended use. As I interpret his original information he is talking 10 walls and therefore when he mentions a door 10 x 9, to me that means 10' wide and 9' high.
My point, which has been mentioned by others, is that a 9' high door can be quite limited in what passes through. It would be a lot less expensive to consider future uses and build higher (or longer) now than to jack up the building later to add a 4' or 6' extension to accommodate future needs. Not just for farm equipment, but for boats, trailers, motor homes, trucks etc. that one might want to get into the shed for storage or repairs.
   / 30X40X10 Pole Barn #18
Since the OP says he will not have power at this barn, I wouldn't waste my money on roll up doors. Without power you wouldn't be able to use it with an opener. I put in one 18x13 slider on each end of my 38x64x14 barn. If you want the door to be in the center on the barn, I'd put in a split slider. I didn't put any Windows in mine, but I have electricity. Since it's in a rural location, I wouldn't put in windows. Make it harder on the thieves/burglars. In your situation, I'd consider the previously recommend acrylic panel 2' from the roof on the side walls. With that and the door open, that will give you a lot of light for a storage barn.
   / 30X40X10 Pole Barn #19
One advantage of roll up doors is they are easy to open. Heck my 5 year old daughter can open our barn doors without any trouble. Plus you can mount to doors anywhere you want as long as you have 12" of clearance above. I have 4 over head doors on my barn and no power. Two doors are 16' wide x 10' high and the other two are 9x8. Its nice to be able to undo the latch and with just a slight lift have the doors up and out of the way. But their not for everyone and every application.
1266 (A50490)
1266 (A50490)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55218)
2016 RAM 5500...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
