3120 bale spear
/ 3120 bale spear #1
itn
western illinois
john deere 3120
does anyone use a 3pt bale spear on a 3120? i was wondering how it performed. thanks
/ 3120 bale spear #2
I have an 870 which sounds like it is about the same size. I use the three point hitch spear just fine. I made a front spear for my front end loader. I just use that to get the round bales off the trailer and into the barn. No high lifting as the round bales are about 1,000 pounds. I would not be doing any high lifting outside. In the barn on a level concrete floor I can lift a bit more to double stack. I do not use it like the hay farmers who have tractors twice the weight and 3 times the horsepower.
/ 3120 bale spear #3
The lift capacity of your hitch is over 2000 lbs, if you are thinking 1000 to 1250 lb bales then no problem assuming you have proper front weight. Not much to a bale spear to go wrong is there?
