Diamond C
Recently bought a jd 3130 knowing that the hyd lift did not work properly and had been setting in a shelter for a couple of years, come to find out the rock shaft bottom rod seal was leaking and leak the hyd fluid out. Replaced the seal cleaned the screen hyd filter and replace the can filter. Power steering worked after that but the lift was extremely slow coming up. Now after about 30 minutes of use the steering goes out, The pto works, lift lifts slowly and now the steering goes when its runs awhile. I can let it set for about 20-30 minutes steering works then again warms up goes out again, Any idea?
