3130HST kinked hydraulic line
   / 3130HST kinked hydraulic line #1
ukininkas
Somehow I managed to kink the hydraulic line going just below my hydrostatic transmission filter to the reservoir. It isn't leaking but a trace of fluid. The kink is about one third of the diameter. Is this a bypass line or a return line? Any harm in running with it that way until the next full fluid change? Thank you for your consideration.
   / 3130HST kinked hydraulic line #2
Without a hydraulic schematic it is hard to tell if it is pressure or return.
No the kink will not hurt anything, I would keep an eye on it because it has been weakened.
Thank you for the response. I don't have a schematic. But I have the new part on order! Not worth snagging something else in the back 40 by the river at the most inopportune time. I already ripped off the speedometer cable shortly after purchasing the machine. My previous 2900GST seemed less prone to this sort of thing. I guess its just the cost of doing business, i.e clearing trails.
   / 3130HST kinked hydraulic line #4
If you do that much trail clearing, I would recommend some sort of under body aluminum or sheetmetal gaurd! Doesn't have to be any-thing fancy! I don't have one on my L3130 HST, but I did have some sheetmetal buddies make me a skid plate for my engine and swing arm on my 2001 Yamaha Warrior 350 4-wheeler, and if I didn't have those my 4-wheeler would already be destroyed!.... /forums/images/graemlins/smile.gif
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2169 (A54757)
2169 (A54757)
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A55787)
2020 Kubota Z723KH...
2015 Toro Workman MD Utility Cart (A55787)
2015 Toro Workman...
JOHN DEERE 2350 TRACTOR (A54756)
JOHN DEERE 2350...
