316 Skip in Engine
/ 316 Skip in Engine #1
Firepuppy
Rome, NY
John Deere 316
Hi Fellows i need your help i replaced my points and condensor on my JD 316 Tractor with an Onan B43E engine hoping to eliminate a skip in the engine but it even does it with the news parts can anyone tell me if im missing something
thanks
Gene
/ 316 Skip in Engine #2
IME, I would double check the points, reset if they are off, start & run a little, check again. If they are still off, could be a cam bearing spun in the end plate.
Ed
/ 316 Skip in Engine #3
Have you ruled out a fuel issue? Or do you know the skip is a spark problem?
How long (duration) is the skip? What seems to cause it to recover? rpm? ??
well im pretty sure its not a fuel problem im leaning more tord a sparkplug wire it doesnt seam to fit tight but when its running i can hear it but it seems to go away i think when i turn on the pto
213065 (A64276)
213065 (A64276)
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
CAT 740 Engine (A68134)
CAT 740 Engine...
INDUSTRIAL GOLD 133 GALLON COMPRESSOR (A67714)
INDUSTRIAL GOLD...
Metal Eagle Weather Vane (A66738)
Metal Eagle...
