318 Slow to Start
   / 318 Slow to Start #11
Wind shouldn't have much effect, I wouldn't think.
   / 318 Slow to Start #12
Have a 318 with the same problem after sitting for a couple of weeks. I use a blast of starting fluid. Works instantly. Also run 0W-30 mobil one to help lessen the stress on the starter and battery in the winter. I have seen threads on WFM about this problem and may try some solutions in the spring time.
Weekend Freedom Machines: Fuel primer bulb for Onan?
   / 318 Slow to Start #13
Hello SeventhSojourn,
I Helped bring those into this world , I work for Chrysler Proving Grounds for 32 years. Retired in Dec. 1998. I don't know if anyone has change the starter on it ? But you can get a Japanese starter Which turns the eng. over faster , for it at Auto Zone. But they had problems with the carbs on them also . The heat from the eng. would boil the gas that was in the carb after it was turned off. I'am guessing that you have a 2 barrel on it? But Chrysler did nothing about it . But they did put different Carbs on then later on. You also can change the carb and also put an a electric fuel pump on it. I do know a few guys did this.
HOPE THIS HELPS YOU OUT!
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
New Long Forks (A53002)
New Long Forks...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
