325 Snowlower Drive Belt Tension
   / 325 Snowlower Drive Belt Tension #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
just had first snowfall. Currently getting a little rubber aroma from drive belt in heavy snow. too tight or too loose? how tight should I adjust. Thoughts?
   / 325 Snowlower Drive Belt Tension #2
Can you give us the model number of the blower?
Richard
   / 325 Snowlower Drive Belt Tension #4
I had a 42 snow thrower on a Deere 325. Had the same thing happened and it was the belt that drives the auger on the blower (vice the belt from the tractor to the auger drive shaft).
I pulled the cover and found the area full of grease from greasing the drive shaft. I cleaned the whole housing out and put a new belt on it. Never slipped again.
Do you have the owners manual for the thrower? If not, check Deere publications for a down load.
   / 325 Snowlower Drive Belt Tension #5
can't find Model # , it the JD 42 inch, single stage snowthrower.
Without the model number, it is hard to look up the user manual.
Can you post a few photos of the unit?
How is the main drive belt tightened?
Richard
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
