3325/3525 owners
   / 3325/3525 owners #1
xlr82v2
Platinum Member
Southwestern Illinois
2007 Mahindra 3525, 1952 Ford 8N
What do you think of your tractor? I'm seriously considering one of the 25 series tractors...
I would have no problems with a 3325, but I sure would like the power steering and live PTO of the 3525. And, I could use the hydraulic remote option on the 3525 as well.
How do you guys like your tractors, and how is the manual steering on the 3325? How well does the draft control work on the 3pt hitch for those of you who do any plowing or such with the tractor?
Sorry for all the questions, just wanting to know... If I get one, it will likely be sight unseen, as none of the dealers close to me have one in stock and say they won't be getting any unless someone orders one.
Thanks!
Brian
   / 3325/3525 owners #2
i have a 4500 2wd, i dont think its too much more than the 3525 and it comes with remotes, i got it with a front end loader and as far as im concerned it doubles the value. i am very happy with it. i have herd the 3525 is an excellent tractor but dont have first hand knowledge.
   / 3325/3525 owners #3
Well here is my 2 cents for all its worth, i have a 2006 3525di with fel, i like the tractor very much, i don't have any negative comments to make about it, before i bought my tractor i have a friend who owns a 3325 and i played with it for a while and really liked it alot, it was the 3325 that got me looking at the 3525's. I just liked the idea of power steering, if you think you may ever want an fel you will need power steering. the tractor is really simple ( thats what i really like about it) has plenty of power, i use mine primarily for log skidding (hardwoods mostly) and for loading work (dirt, limestone, etc.) good luck on your choice, if you need anymore info i don't mind giving it to ya.
   / 3325/3525 owners #4
I have the 3525 w/FEL and have been very pleased with the tractor. I have around 175 hours on it. The FEL has worked great and I also pull a 6 foot brush cutter. As the others mentioned, I do enjoy the power steering.
   / 3325/3525 owners
How do you guys like the power? If I get one, it will be an upgrade (that's an understatement!! /forums/images/graemlins/smirk.gif) from my '52 Ford 8N. I've got a 5ft Rhino SE5 bushhog... and I'm wondering if that will really be too small for the tractor. How does it run a 6 ft cutter? If you guys with 6 footers can cut a 6ft swath through just about anything at 3-4mph, then it might be worth it to get a bigger cutter.
Thanks for the replies!!
Brian
   / 3325/3525 owners
Murray,
Do you have a groundspeed chart for the 3525?
   / 3325/3525 owners #7
I will see what i can come up with for ya, i will look in my owners manuel and if i have to call my dealer. get back with ya soon
   / 3325/3525 owners #8
Sorry i took a couple of days to get to you, i got three kids and a wife and i had to complete all the other stuff first. But good new is i did find a ground speed chart that tells you how fast in mph per gear in high and low. i found this information in my owners manuel under specifications sections. Again if you need anything just let me know,
L1-1.39mph
L2-2.37mph
L3-3.38mph
L4-5.05mph
LR-2.11mph
H1-4.10mph
H2-6.91mph
H3-9.84mph
H4-14.71mph
HR-6.14
   / 3325/3525 owners #9
I don't let my grass get way too tall, but I usually bushog with the 6 foot cutter in low 4 and it looks good when done. I usually cut it once a month. I was told by the dealer that it would pull a 7 ft finish mower.
   / 3325/3525 owners #10
Hutchinson 10" Transfer Auger (A50514)
Hutchinson 10"...
Onsite begins 8:30am / Online begins 9:30am (A50120)
Onsite begins...
1600 gal Poly Tank (A50515)
1600 gal Poly Tank...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
John Deere 6115M (A50120)
John Deere 6115M...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
