340 international tractor
/ 340 international tractor #1
McLeansboro,Illinois
340 international utility tractor
On a recently acquired 340 International Utility tractor , when I worked the lever on the touch control on the Hydraulic valve, I don't seem to get any oil back to the hydraulic cylinder for the 3 point hitch, but I get a loud squeling noise from the hydraulic pump, like its bucking pressure. WHAT IS THE PROBLEM ?
/ 340 international tractor #2
Sounds like the hyd flow is blocked somewhere.
Check all Quick Disconnects if you have them.
/ 340 international tractor #3
It could be the inline check valve sticking. I'm assuming yours has a double acting cylinder. I have a 240, so not exactly sure where it's located on the 340, as there are a few differences in them. But should be between the Hyd. control valve, and cylinder. Here is a link to the Case/IH online parts store exploded view of the check valve. Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
Could be a possibility there is a piece of debris in the check valve, not allowing it to activate.
