345, blade tilted
   / 345, blade tilted
P/N - M121038 - $4.46 plus shipping.
From what I can find, those wheels are only for transport purposes when the plow is disconnected. I think the transverse rod needs to be adjusted. The two circled clevis connectors need adjusting too, just like a mower deck. The right one can be shortened and the left one lengthened, or whatever combination works.
This could be the culprit as the tractor and blade is new to me. I hooked it up as is and just assumed everything should be hunky dory. It's not the end of the world, I just have to watch the edge of my driveway so I don't tear up the grass. Happy New Year
   / 345, blade tilted
I am curious as to the operation of the blade. What raises and lowers it? Those skinny little arms going to the rear?
345 uses a hydraulic lift for raising and lowering.
   / 345, blade tilted #14
Yes, see the attachment (Attachment 533471) posted by K7LN and the lift links circled in yellow.. Likely this is where the adjustment is to level the blade too.
Same connection/lift used to lift the mower deck ??
   / 345, blade tilted #15
I have a center blade that pivots on the rear of the tractor and lifts like this blade does. Evidently it does, but I can't imagine how it will lift a heavy blade with anything pushing on if levered way out in front of the lift mechanism. Maybe that's why I am not an engineer.
   / 345, blade tilted
I believe the lift mechanism attaches at the rear of the plow, not pictured above. I only speculate bc that's where the mower deck attaches
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
43016 (A51691)
43016 (A51691)
2007 Bobcat T190 Skidlaoder (RIDE AND DRIVE) (A50774)
2007 Bobcat T190...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A50323)
2015 Freightliner...
2022 Globe Trailers 53ft 65-Ton Tri-Axle Lowboy Trailer w/ Stinger (A50323)
2022 Globe...
