3500 - SRW VS. DRW
   / 3500 - SRW VS. DRW #32
Something some guys who max their duallies out can tell you, if you are fully loaded and lose a rear tire, the remaining tire is overloaded you generally won't get far before it fails too, even slowing down. I should be clear, won't get far in terms of a trip. You will need to find another tire as you won't be able to run at highway speed.
   / 3500 - SRW VS. DRW #33
The real issue with a flat is what happens to the tire -- does it rub up against something, get hot, and start a fire? As we all know, once a tire starts burning, it is real hard to put it out, even with a fire extinguisher. So if you have a flat and don't notice it, count yourself lucky your truck didn't burn up!
   / 3500 - SRW VS. DRW #34
with single.. with a blowout.. you may be up the creek.. with a dual rear wheel.. you have a lil better chance of keeping control and pulling over at least.
WORST case is you drop the trailer.. or limp to an offramp.
single rear might have you in the median or a ditch.. ( might get there with the dual as well.. but a lil better chance to avoid catastrophie .. )
   / 3500 - SRW VS. DRW #35
I went from an 03 2500 duramax to a
06 3500 DRW duramax. towing wise it is awesome. But man it sucks of road and in the snow, it is really bad in the snow. But except the off road thing, i do love the truck. Going from srw to drw male a whole diffrence when towing.
   / 3500 - SRW VS. DRW #36
yep.. i won't tow with a srw again ( i hope.. )
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
SDLanch SDLGC80 Electric Golf Cart (A57149)
SDLanch SDLGC80...
THREE POINT MAINTAINER BLADE (A58216)
THREE POINT...
