3510 Lift Capacity & Hydraulic Pressure
   / 3510 Lift Capacity & Hydraulic Pressure #11
GIJOE said:
My 3510 is a shuttle shift.
So you have a ML112 loader. The hydro used a ML108. rback33 will have to advise, but that tractor may have a prince valve with a pressure relief in the valve.
   / 3510 Lift Capacity & Hydraulic Pressure #12
According to the ML112 manual that came with my loader the relief valve is part of the loader control valve.
   / 3510 Lift Capacity & Hydraulic Pressure #13
The Nimco valve was used for quite a while and it had the pressure relief in the valve, but they are no longer used. I just went out to the lot and looked at a new 3510 shuttle with ML112 and Prince valve. This valve does not have a relief, so Mr. rbackk33 is likely correct on this one. So the poster will have to ask the dealer to check the tractor system pressure relief.
   / 3510 Lift Capacity & Hydraulic Pressure #14
The ML112 with the Prince valve does not have a relief. I believe that the only loader 112 or smaller to have a relief was the 108H on the 2810 and 3510 HST. I would have to check the cheat sheet in my desk to be sure.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
2019 TAKEUCHI TB230 EXCAVATOR (A51246)
2019 TAKEUCHI...
2009 ARROW BOARD MODEL - 9069 (A51247)
2009 ARROW BOARD...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51247)
JOHN DEERE 975 3...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
