3510i hydraulic pump noise
   / 3510i hydraulic pump noise
Thanks so much. I know the area like the back of my hand...used to live in Byron. -Even built the Pec water tower.
   / 3510i hydraulic pump noise #12
When you built the new tower in Pec I lived about a mile away on the east side of town, probably ever swore at you SOB's for screwing up the traffic and streets:D have since moved out into the country.
   / 3510i hydraulic pump noise #13
I have a different tractor but I got the OEM Branson filter on line for about $25 at either Amazon or ebay. However, after SH the total was around $50. I don't have a dealer close by. I guess I could have called them and had it shipped. Probably would be the same money. I don't loose very much oil changing filters either. However, I get everything ready and the spin the old off and stab the new is pretty fast.
Mine has a little whine at the higher rpms. Below about 2400 it's quiet. I know it does it under load; don't remember it doing it unloaded. Very well could be just gears getting used to each other. I don't have any instability with any hydraulics including loader operation. I have had this tractor since 2007 and it is just now loosening up where things like shifting in/out 4wd is easy. It's rated hp is at 2500 but the factory set the pump up to 2700, I guess to ensure that tractors out the door meet the specs. It is very well built, that's for sure.
My first reaction to your post would be air in the system, but just changing the filter that should be minimal and you said unloaded, not loaded. Just don't know.
Mark
Thanks Mark. Yeah....that's the weird thing...quiet as can be when loaded, but makes the whine unloaded at any rpms. -Talked with a tech at a dealer and he is gonna talk with some other folks. I'll keep all posted.
Just a quick update...thanks guys for your help and thanks to Ron at NITE equipment. Branson hydraulic filter solved the pump noise issue. My boys at the back of tractor with a shop vac and me changing filter....only lost about a quart of hydraulic fluid. Sweet.
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
