dirtworksequip
Veteran Member
- Joined
- Jun 3, 2006
- Messages
- 1,453
- Location
- Wheeling, WV
- Tractor
- 2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
I was out grading up a road today and went to set the cruise control and error code 05 came up and the cruise function did not work. Shut it off and restarted. No code. Pushed the cruise switch and code came up again. I finished what I was doing and then looked in the manual.Err 05 Brake and Cruise Set/Decel Switch. ( PROBLEM SOURCE: Cruise control set/Decel switch depressed while brake is engaged.) (ACTION: Release brake pedal.) But the brake pedal was not depressed or PARKING BRAKE was not set.
So I thought I would disconnect the battery and see if that might clear it. If that did not work I was going to check out the cruise switches to see if one may have come loose.
But, before I do that maybe pull up on the brake pedal. Shazzammmm! That was it.
