3525 owner has 3pt plow question
   / 3525 owner has 3pt plow question #1
boog0909
fingerlakes area in upstate ny
John deere 5055 & mahindra 2015
looking to buy a plow for plowing a couple acres before i hit it with the disc.My question is should i looking at a single or can i use a 2bottom the soil is pretty heavy some clay . I believe the tractor weight is around 4400lbs and engine hp is 37. Any responces would greatly appreciated
   / 3525 owner has 3pt plow question #2
It should handle 2 16" bottoms quite handily. Where are you located, my daughter lives on Seneca Lake. Also when buying a used plow, make sure the bottoms are true and not sprung. There are a lot of bad ones out there.
   / 3525 owner has 3pt plow question #3
Your tractor will handle a two bottom plow no problem.
I'd recommend two 16s. Make sure you get a plow that
has good coulters and is adjusted properly on your hitch.
3 New 14in Premium Diamond Blades (A50322)
3 New 14in Premium...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2022 Deere 317G (A50120)
2022 Deere 317G...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
