3600 Ford
/ 3600 Ford #3
diesel fuel bleeding the lines
their are 3 or four small lines at the top of the tractor need to open slowly while starting the tractor one at a time watch for air to come out of the lines
I once opend all of them at once and got the tractor to start shut it off and closed them all
also on the right side their is a pump that the lower line needs to be opend slowly while starting the tractor watch for air to come out of the line and then bleed the top lines if it dose not start
took me 3 times to remember to always check the level my gage dose not work so a clean stick from the ground?? will work
trial and error taught me how to bleed the lines. so could be a better way
