3616 Mahindra-battery is hot-nothing happens when I turn the key
   / 3616 Mahindra-battery is hot-nothing happens when I turn the key #11
Ive had bad connection where the cable connects to the battery lug.
   / 3616 Mahindra-battery is hot-nothing happens when I turn the key #12
if you haven't figured it out yet...i had a similar problem on my 3016. turn key and nothing. turn key and glow controller buzzes...... somtimes the lights worked..... all it really is, is a ground issue 99% of the time. at least in my case. i got rid of the finicky connectors from the factory. ground the frame a little more at the bolted ground connection. they also did have a bad batch of exide batteries that would leak and corrode etc... its warranty if u remember before 3 years is up... anyway i replaced mine from canadian tire. got one that was a close match, as they didnt have a exact match. had to make a wider battery hold down bar like 3/4 inch if i remember..... i went thru just about everything when it did it to me, i was frusterated then last thing i think of is the ground..arrg:confused3:
John Deere 920 Platform (A50514)
John Deere 920...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2020 KUBOTA RTV...
