3720 hst w/o cruise?
   / 3720 hst w/o cruise? #1
massiveSnow
idaho
the 3720 comes standard with hst and without elect. cruise. Is there some mechanism for more or less holding a constant speed if the cruise option is not included?
   / 3720 hst w/o cruise? #2
I would imagine there is a lever to lock the foot pedal on it somewhere.
   / 3720 hst w/o cruise? #3
Actually the 3720 does come standard with electronic cruise control. The standard cruise allows you only to set the speed and turn it off, but that may be enough for you. The optional automotive cruise upgrade kit gives you accelerate/decelerate/resume in addition to the speed set.
In my opinion the cruise works very well and will maintain a constant speed within 0.1-0.2 mph as long as the load doesn't go higher than the power available from the engine.
   / 3720 hst w/o cruise? #4
here it is from Deere.com:
Automotive cruise/SpeedMatch and MotionMatch control upgrade kit consists of cruise and accel/decel/resume functions, SpeedMatch, and MotionMatch switches. This kit fits all 3120-4720 eHydro models cab and open station.
Automotive cruise allows the operator to accel, decel, and resume set speeds. SpeedMatch allows the operator to preset their maximum eHydro speed for operation. Ideal for applications requiring set speeds (spraying/aeration).
The MotionMatch switch allows the operator to make instant adjustments from short to long rollout and is ideal for operators that frequently change jobs (for example, from mowing to loader work)
SpeedMatch also works like a creeper gear.
This is a $90 uppgrade that is a very easy install. It is well worth having, but also makes a nice add on for later. (Print out the description with part numbers and lay it out conspicously before christmas, fathers day, or...)
Assorted Steel Pipe (A53316)
Assorted Steel...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2006 International 7400 Tandem Axle Dump (A47477)
2006 International...
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
