3720 steering grease points?
/ 3720 steering grease points? #1
nhemmer
Newberg
John Deers 3720 Cab tractor with 300CX FEL
I just bought a 2007 3720 cab tractor and the steering actuator does not have grease zerk on either end. Any ideas on how to properly lube this?
/ 3720 steering grease points? #2
The end is "lubed for life". If it really bothered you you could drill the end for a zerk or use a needle end for a grease gun and puncture the boot, fill it and put some silicone on the hole. As made from the factory it should be good for at least several thousand hours.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 GENIE  GTH1544 (A67714)
2014 GENIE...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
2007 KENWORTH (INOPERABLE) T880 (A67714)
2007 KENWORTH...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
