3720 Vertical Exhaust??
/ 3720 Vertical Exhaust?? #1
sunnyside360
Veteran Member
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
I have been considering the vertical exhaust kit for my JD 3720 w/cab -- just to look more like a tractor. But, what are the advantages of a vertical exhaust vs the standard horizontal exhaust? Thanks in advance.
/ 3720 Vertical Exhaust?? #2
Pro: Keep any sparks off the ground
Negative: More noise near your face, more smoke near your face, rain down the pipe, Can you open the hood with it in
Thanks, Flywheel. All good points. Think I'll stay with the standard horizontal exhaust. I understand you must detach the upper section of exhaust pipe prior to lifting the hood.
/ 3720 Vertical Exhaust?? #4
The noise is not noticeable between them. IMHO, the biggest advantages of the vertical exhaust is 1. Don't get soot on the FEL/tractor with vertical exhaust. 2. Exhaust fumes are much worse when working on the ground near the front of the tractor or FEL with horizontal exhaust. 3. It just looks cool! The exhaust fumes are not bad when vertical. The exhaust can be directed to the side or front.
The biggest negatives for vertical exhaust is the cost and having to remove the pipe to lift hood.
Thanks Radman for your take on it. All good points for verticle exhaust. If memory serves me right, you have a 3720 Cab --- do you have the verticle exhaust??
/ 3720 Vertical Exhaust?? #6
Yes, I have the vertical exhaust on a 3270 cab.
/ 3720 Vertical Exhaust?? #7
Every once in a while I a see a post like this where someone wants to change to a vertical exhaust to make their tractor "look more like a tractor". I have a horizonal exhaust but IMHO my tractor still looks like a tractor. You would never mistake it for a car, SUV, bus or an airplane.
My dad used to have an old David Brown tractor with vertical exhaust. You would get more noise from it but worse you would get the exhaust in your face because the top of the stack was about at head level. Now if you always drove in reverse it wouldn't be a problem. The other problem would be tree limbs. Every once in a while while mowing near some tree you might hit the vertical exhaust on a tree limb. Of course it always served as a good warning because if you kept going you'd get a tree limb in your face. Pretty much this problem was from working in tight areas with trees where you had to rock back and forth to get into tight areas.
When I bought my JD 5320 I made sure I got it with a horizonal exhaust. I don't have a problem with setting things on fire as I'm not working that type of crop/field. You will however get some exhaust if the tractor is running and you are messing with your 3-point implement.
When I bought my JD 5320 I made sure I got it with a horizontal exhaust. I don't have a problem with setting things on fire as I'm not working that type of crop/field. You will however get some exhaust if the tractor is running and you are messing with your 3-point implement.
Thanks Clembert for your thoughts on the subject. The 3720 horizontal exhaust comes out the front so not much in the way of smoke/fumes in the face. I'll probably just stay with the horizontal exhaust until if/when the vertical would be more beneficial.
Thanks again to all for your responses.
/ 3720 Vertical Exhaust?? #9
Sunnyside, I changed over to the vertical exhaust on my 3520/cab tractor for a couple of reasons. I didn't like the exhaust in my face with the horizontal exhaust when I was getting anything out of the bucket by hand. Another reason was when mowing or working on dry dirt or a dry stone road in dry conditions the horizontal would stir up a lot of dust and debris. Not a problem for my lungs with the cab tractor,but that extra dust is being sucked into the tractor's air cleaner and cab filter.
The horizontal also made the tall grass move next to where it exited and gave me the illusion when caught out of my peripheral vision that something was being hit with the front tire causing it to move. Something was moving where it wasn't supposed to be moving. I didn't like that feeling.
All in all I'm satisfied with changing over to the vertical exhaust. The cons to it are cost, having to remove it to lift the hood and I just had mine get stuck on because of some rust. The install takes less than half an hour.
Sincerely, Dirt
Sincerely, Dirt
Thanks Dirt for your response. All good input. I'm undecided as to what to do and will probably wait a bit longer.
Sunnyside
/ 3720 Vertical Exhaust?? #11
I agree with both radman1 and dirtworksequip
I installed one on my 3520 Cab because I did not like all the soot that ended up on the loader arms and then on my shirts. By the way, the top on the exhaust is bent at a 90 degree angle so there in no rain going down the pipe.
I would do it again. Very satisfied with it.
/ 3720 Vertical Exhaust?? #12
Hi Sunnyside:
I have a 3320 with the standard exhaust. Previously I had a factory vertical exhaust on a Ford NH, and while working in the woods broke it off on a tree limb. I agree with ClemBert. Looks are not important to me and for working around trees I much prefer not to have the pipe exposed. If I were working fields I might change my mind.
Steve
/ 3720 Vertical Exhaust?? #13
Can anyone post a photo of a 3000-twenty series tractor with the vertical exhaust installed? Interested to see what it actually looks like.
/ 3720 Vertical Exhaust?? #14
I have it on my Cab tractor..... and I won't ever go back to the ground exhaust ever again. Like said above.... it takes only one wiggle and pull to take it off to open your hood... And I too don't like the soot on the loader arms and tire rims etc.... As far as noise difference, well... I don't think it would be much different at all... but then again... I'm in a nice quiet cab....
/ 3720 Vertical Exhaust?? #15
jcote, here's a couple of pics of my 3520 with vertical exhaust.
Below pic: 3520 vertical exhaust.
Below pic:vertical exhaust removal
Sincerely, Dirt
/ 3720 Vertical Exhaust?? #16
All the points (advantages) I was going to bring up were all mentioned. We put them in both our 3520s and would never go back. Our Front mount blowers would be black by the end of the 12-hour run from the soot.
I love the look of the vertical, and like you guys said just a wiggle and it's out if you need to lift the hood.
However, just a tip: If ever you're floating the machine I think it's recommended to turn the exhaust sideways (or reversed) and not forward. Depending how fast you're floating the unit, the wind could spin the turbo in the opposite direction and potentially cause damage to it. Not sure if this is 100% true but I would not take a chance on my machine.
/ 3720 Vertical Exhaust?? #18
What is Floating ??:confused::confused:
I'm guessing "floating = towing." Now we need someone to make an exhaust pipe rotator along the same lines as a snowblower chute rotator. :rolleyes:
As for me I can live with soot on the loader from the ground level exhaust. As for exhaust blowing on me while hand shoveling junk out of a bucket, I put it in idle for a few shovels of stuff and shut it off if I have a lot to hand shovel.
One could always put a bucket over a vertical exhaust without a raincap. I see that a lot around here.
I have enough fun wearing bifocals, so I don't need a vertical exhaust in my direct field of vision. Yes, I know, I have two front posts for my canopy; but they are similar in my field of vision as a car's "A" pillar.
/ 3720 Vertical Exhaust?? #19
I switched to the vertical kit on my open station 4720, mainly because the fumes that would come my way if I was working into a headwind were nauseating, and hot. It didn't change the noise one bit (most seems to come from under the hood, not the pipe). The install took 30 minutes (and I'm no mechanic), and the pipe takes, oh, 4 seconds to remove to lift the hood. It can be pointed forward, left, right, or back in 90deg intervals. I think it cost ~220 CDN.
Oh, aaaaaanddd, don't tell anyone but I like the way it looks too......
-J.
/ 3720 Vertical Exhaust?? #20
-J.
So how did it do in getting rid of you breathing the fumes?, and which way do you have the tip pointed to get the least amount or no fumes? I have the VE kit waiting at the dealer for me to pick it up when I have a free moment and I'm debating whether to install it or not. My biggest issue is breathing the fumes, the noise or visibility aren't a problem to me.
