3830 won't start after 50 hour service, help!
   / 3830 won't start after 50 hour service, help! #21
Re: 3830 won\'t start after 50 hour service, help!
Which procedure did you use to bleed the lines? The one in the manual or advice from another poster on this forum? Just curious.
DaGoatMan
   / 3830 won't start after 50 hour service, help! #22
Hello,
Just read this thread, glad you got it running.
I did the same thing on my L3430 when I cleaned the filter.
It started then died.
When I checked the manual, it led me right to the bleed.
Only had to loosen cap and crank engine.
It started right up and has been fine /forums/images/graemlins/smile.gif.
ksmmoto
DaGoatMan,
I used the advice given by TBN posters, but it was very similar to what I found in the manual after reading the posts here. I loosened the bleeder screw and the tractor fired right up. I then closed the screw and it stayed running. The 3830 and I have been happy ever since.
Lawrence
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2001 International 4000 DT 466E (A60462)
2001 International...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
