3ph adapter on loader arms
   / 3ph adapter on loader arms #1
eteagle
Illinois
JD 3300
Is it possible to attach a speeco 3ph quick hitch to the loader arms of my JD 4300 with 430 bucket?
Please advise.
Thank you
Ernie
   / 3ph adapter on loader arms #2
If you can weld, virtually anything is possible. /forums/images/graemlins/smile.gif This sounds like a fairly simple project, actually. Why to you want the Speeco up front? Looking to use a back blade for snow plowing or use a set of pallet forks up front? Just curious... /forums/images/graemlins/smile.gif
That's exactly what I want to do.
Ernie
   / 3ph adapter on loader arms #4
Can u weld or are u looking for parts?
ATI which advertises on here has the adapter to go on your loader to the skid steer loader(SSL) mount.
U could use SSL buckets or weld the plate to your bucket.
Then get the SSL to 3 PT adapter and u are set.
I built a SSL to 3 PT on a plate so I could take the Speeco QT off and use it on the tractor.
4 pcs of 2x3x1/4x18" or so long angle for the pivots and 2 pcs 3x4x1/4x 36" long angle for the top and bottom cross pcs will build the frame.
I used 1x3x5" strap w/7/8 hole for the bottom pins and 2pcs of 3/8" thick straps for the top link.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
