3ph lowering limit on a B7300
   / 3ph lowering limit on a B7300 #1
DmansPadge
Orange, TX
Kubota B2620, Toro 2000 Series Z Master
Hey guys. I have been involved in a similar discussion on another forum but I wanted to get some of the Kubota guys input. I have a B7300 and I will soon be buying a 4ft brushhog. I had asked some questions about setting the height on the brushhog. Sneakypete gave me some great info on using check chains which seems easy enough. However, I was looking through my owners manual, and noticed that there is an adjustment to change the lowering limit of the 3ph. It is simply a bolt that you can screw in or out to change the lowering limit of the 3ph. It is located just to the right of the lift arm. The only guy I know that has a tractor like mine is Sneakypete and he said he has never tryed using it. I was wondering if anyone else has this option and ever uses it? I know I would have to adjust it from implement to implement, but, once I put on the brushhog it will stay on for extended amounts of time so I'm not worried about that.
Thanks!
Anyone...... anyone? I'm going to get the brushhog Friday. Anyone.....?
Thanks
   / 3ph lowering limit on a B7300 #3
Yep. I have the same adjustment on my BX. I have used it with success for my rake before I had guage wheels.
</font><font color="blue" class="small">( Yep. I have the same adjustment on my BX. I have used it with success for my rake before I had guage wheels. )</font>
Thank you! I posted this one a few days ago and I didn't get any replies!
Does this take the strain off the hydraulics? Does it work like using check chains would and let the 3ph rest at the desired level?
Thanks!
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
