3point hydraulic distribution valve is new still leaking down
   / 3point hydraulic distribution valve is new still leaking down #1
Charles 1947
2425 farm pro
1985 farm pro replaced hydraulic distribution valve but 3point is still not working properly it leaks down what's my next step any help would be greatly appreciated
   / 3point hydraulic distribution valve is new still leaking down #2
The first thing would have been resealing the 3pt cylinder piston. To diagnose, with weight onvyour hitch, raise your 3pt up, turn the 3pt rate drop valve off/closed, assuming it has one, and turn the tractor off. If the hitch drops, then it is the piston seal.
   / 3point hydraulic distribution valve is new still leaking down #3
Just found this post after posting my response:
2001 GMC C7500 Tree Truck (A55272)
2001 GMC C7500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A58375)
UNUSED CFG...
UNUSED AGT INDUSTRIAL PD680-PZ HYD DROP HAMMER (A58376)
UNUSED AGT...
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
