3pt ball joints, to grease or not to grease?
   / 3pt ball joints, to grease or not to grease? #11
<font color="blue">.. lube plus grit = grinding compound.. </font>
Thats my feelings too Soundguy. I either use a dry lube or noth'n if working in the dirt, sometimes less is best.
   / 3pt ball joints, to grease or not to grease? #12
I agree. I use lockease. It is graphite with a liquid carrier that evaporates to just leave graphite behind. Does not hold dirt.
   / 3pt ball joints, to grease or not to grease? #13
Good thread, I hadn't thought much about the "lube them or leave them" schools of thought on ball joints and other moving parts subjected to a lot of dirt and grit. I've been lubing them, but now I'm leaning toward the Soundguy camp -maybe I'll start using graphite in a spray can. Could be that I've been "killing them with kindness".
For other applications not involving the "grit factor", I just wanted to put in a good word for "penetrating grease", which I had been using on the ball joints and sleeves up til now. It's great stuff and IMHO protects much better than WD-40 for metal-on-metal lubrication. It sprays on thin to get into tight places like a penetrant, then thickens up to act more like a grease. Good stuff. I still use WD-40 for drying out ignitions.
For loosening rusted nuts and bolts and other stuck things, WD-40 used to be my penetrating oil of choice years ago, along with Liquid Wrench, but that was when I was young and even more foolish than I am today. Later, PB Blaster won me over, it really is good. But I think the king of them all for loosening things is this stuff called Aerokroil. Try it if you can find it, I think you'll be amazed. Sure is stinky though.
There's one other thing I might try on the ball joints - molybdenum disulphide spray - it goes on wet, then dries leaving a thin coat of lubricant that wouldn't collect grit the way oil or grease would.
   / 3pt ball joints, to grease or not to grease? #14
Graphite is good on the pto splines and push buttons too.
   / 3pt ball joints, to grease or not to grease? #15
I have started using a bicycle chain lubricant that is paraffin based with teflon. It goes on wet for good penetration and then dries to keep dirt attraction down. It's made by Finish Line.
   / 3pt ball joints, to grease or not to grease? #16
I've always greased the heck out of 'em for over 20 years now. If you're afraid of dirt getting in your grease, make sure that you don't grease any of your FEL joints. They get just as much dirt if not more. Other than sometimes cussing about getting grease on my pants when brushing against them, I've not had any other issues. But, hey, I consider grease as being cheap. I could always whack sloppy ball eyes off and weld on new ones, but I've never had to.
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
