3pt hitch downward pressure?
   / 3pt hitch downward pressure? #11
talk to a local extension agent to find out soil types in your area..
I'm wondering if I might be able to get the job done with a 4' boxblade and a york rake? Using the bb instead of using a disc harrow(which I don't even own anyhow)?
   / 3pt hitch downward pressure? #13
I'm wondering if I might be able to get the job done with a 4" boxblade and a york rake? Using the bb instead of using a disc harrow(which I don't even own anyhow)?
First of all, a 4" (inch) box blade is awfully small. Something larger would make the job go much faster.:laughing:
The tines on a box blade will work fine for tearing up the ground. It will look like a mess until you level it out. Hard clods and old dried sod will be your enemy.
You will find that a york rake, if used for leveling, will pick up clumps of anything, sod, roots, leaves, etc. and fill up much like a box blade. The soil needs to be very fine for a rake. A rototiller can accomplish this. (Some people swear by a rake for leveling gravel but usually there is a pair of training wheel involved.:) )
You can forget about a disc if you don't have access to one. The tines will work well enough for the job you want to do.
Oh that sounds great! last time I did a yard was mine 20 yrs.ago!My neighbor disc n drag it and I used a 3' or 4' pull behind york rake on a Bolens 10hp I had..and killed lol! I did my 3 acres, what a chore! This should be alot less demanding, though I do worry about the unknown-Tree roots evidently this was previously a treed lot..:( I suspect we may have a bunch of roots to contend with. This should be a good challenge to get 'er done in 2 days..:confused2: It'll be a good experience for my son too!:thumbsup:
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
