3pt pallet forks
   / 3pt pallet forks #1
Agrantina
Platinum Member
West Tennessee
Kubota L3240 GST
Anyone ever use 3pt pallet forks? I may be get a side job to lay 20 pallets of sod soon and I am wondering if this is worth my money? I have a L3240.. or are there other items to move sod pallets around with??
AndyG
   / 3pt pallet forks #2
We use to take old forklift forks and turn them into 3 point setups. Make sure whatever you get has a nice wedge shape like so- >
It makes it easier to get under the pallet without barkign the boards, backup slow and sdjust your top link as needed, which seems all the time unles you are doing it on nice even ground.
   / 3pt pallet forks #3
I made a set using a forktruck sideshifter frame and a set of forks. They are very useful, but you are limited on lift height with the 3 point hitch. If you have a loader, forks are far more versatile when mounted on them.
   / 3pt pallet forks #4
I made an adapter to use my Frontier quick attach forks on the three-point hitch.
   / 3pt pallet forks #5
I also use my Deere forks on the 3 ph iMatch. Having the hydraulic top arm is almost a necessity to be able to pick up pallets with the forks on the 3 ph. Also, the top arm when retracted makes reaching the lockdown levers so much easier to reach from the tractor seat, making it easier to just stay seated while exchanging attachments.
   / 3pt pallet forks
Thanks guys... I will have to see if I get the job.. If I do? I bet they would come in handy :thumbsup:
AndyG
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2013 Ford Escape SUV (A55758)
2013 Ford Escape...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
