3pt terminology
/ 3pt terminology #1
raykos
Central Pa.
JD2305
Hi all,
A lot of attachments I've seen that connect to the 3 point hitch of the tractor use what I'm, at the moment, calling a "mounting triangle". What is it's proper name? And like a triangle it has "2 sides & a base"; again, what are the correct names? Also, is it possible to build your own? And if it is, can it be built without welding? If so, any pictures, sites, etc. appreciated?
Thanks,
Ray
/ 3pt terminology #3
Are you talking about a triangle-style quick hitch like the ones mentioned in this thread (especially this link)? They consist of a part mounted to the tractor and another mating part that mounts to each of your implements but they're largely proprietary. The U-shaped hitches are more standard, but have issues with lower connection widths and/or toplink height.
/ 3pt terminology #4
I've never heard of a single name for the triangle you describe, other than the three point hitch. On the tractor side it is made up of two lower links and one upper link or top link. On the implement side, there are two lower link pins and one upper link attach point. I believe there is an SAE standard for the dimensions and such, but I don't have my SAE books here.
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2013 CATERPILLAR 120M2 MOTOR GRADER (A63276)
2013 CATERPILLAR...
