daTeacha
Veteran Member
Yeah, that's what I was refering to as the levers making up the rest of the system. It just seemed that everyone was forgetting that different cylinders connected to the same pump can exert different amounts of push even though the pressure is the same. If you have the physical room, you could put bigger cylinders on a FEL to lift more, but it could cause damage to the arms or something even though the relief valve doesn't open. If it didn't do that you could end up lifting way too much weight too high and tipping over more often than you'd like.
