3pt won't lift fix
   / 3pt won't lift fix #1
BriManley
Mahindra 6075
Thought I would post an interesting resolution for anyone struggling with their 3pt hitch not working. Recently had a Mahindra 5010 cab that was working fine and then one morning the 3pt would not lift and the rear aux plugs wouldn't work either. Loader worked and its a HST so it did move. After two days of troubleshooting, decided to replace 3rd function WR Long joystick switch because it just didn't feel right for the grapple and it had been acting up. Come to find out the $25 switch was the culprit for shorting out the rear hydraulics. Still don't understand why since the grapple actuator is electric and the 3pt is mechanical. Regardless, all is working as expected with the switch change.
Hope this helps someone.
   / 3pt won't lift fix #2
Possibly the malfunctioning 3rd function switch caused solenoids to operate irrationally and there for block the hydraulic flow to rear and diverted flow to "tank"... As generally 3PH is last hydraulic operated function on most tractors....
2018 John Deere 6195R (A57148)
2018 John Deere...
POOL PUMP / FILTER MAYTAG WASHING MACHINE (A58376)
POOL PUMP / FILTER...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Delivery Truck (A59230)
Delivery Truck...
(3) 12"X40#X86.5" I BEAM (A58375)
(3) 12"X40#X86.5"...
2020 DRAGON ESP...
